Configure TACACS+ Accounting
Determines for which applications TACACS+ collects accounting information. Use TACACS+ accounting to track the services that users access and the amount of network resources that users consume. If unassigned, TACACS+ does not perform the accounting function.
If enabled, TACACS+ accounting logs the following events:
  • User log on and log off
  • Log off generated because of activity timeout
  • Unauthorized command
  • Telnet session closed (not logged off)
If unassigned, TACACS+ does not perform the accounting function. No default value exists.
    enable
    configure terminal
  2. Enable TACACS+ accounting:
    tacacs accounting enable cli
  3. Optional: Disable TACACS+ accounting:
    no tacacs accounting cli
    tacacs accounting disable [cli]
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#tacacs accounting enable cli
